A little crossover from the Reddit 3DP community.
@jane_lucas how about you take whatever scam you’re trying to pull and cram it right up your ass!
I’m almost glad I don’t have an Anet A8
@Samer_Najia same man. No regrets just building my machines and spending a little more instead. I can sleep at night knowing how it was put together.
Another problem point is the low voltage. The cheaper machines use 12VDC. A 24VDC electrical system tends to reduce problems. 12VDC needs higher current to do the same job and it’s the current that generates the heat in electrical contacts.
Listen mate, my whole house burned DOWN
