Ariel Yahni Can't add pics to the comments for some reason
@Derek_Schuetz PWM connected on L (not IN) in my case.
we are mixing 2 different things here. command (pulse) and V for intensity, maybe I am wrong for both to be considered on IN at once. (your case)
latest info from JNMYDY
http://www.jnmydy.com/comcontent_detail/&FrontComContent_list01-1285720952066ContId=6&comContentId=6.html
Ok I may just be confusing the terms but if it’s working its working. Unfortunately the board I ordered is in responsive I think it has nothing flashed onto it and needs to be hooked up with a UART module and reconfigured
@StephaneBUISSON ​ I meant if I set the pot dial to 5mA with your config my max would be 5mA. But when I run a job I only the max power to 5mA.that being said I just realized that I’m setting 100% power on LW, so if I set LW to something bellow the equivalent to 5mA I should get less power?
