@Eclsnowman Looking back at what I did, I’m certain i was copying/pasting the value (link text/url) from same Part Number cells. I see what happened though… I sorted a specific column, I believe Part Number, to make it easier to see what had links and what didn’t. That’s the only thing I can think of because there is one revision from your first change and mine at 9:44am CST.
Will keep you posted.
I’m retracting viewing privileges from the general public and until I can get that column back to good… and NEVER sort on part number column ever again.
Sorry all, for the inconvenience.
@Seth_Messer I hope you didn’t take offense. But yes if you do a sort, then drag copy it unfortunately brings more than the values along for the ride. But everything can be fixed. No big worries.
@Eclsnowman no offense taken at all! i was just bummed to have caused you grief with this. was wanting to do this to help you out and get it to a point where people can see what’s changed if more changes are necessary. that said. i fixed it all.
i still haven’t filled in the “openbuild” vendored items with their links, but i believe that’s all that’s left. please give it a once over if you don’t mind.
@Seth_Messer looks great. I will try to add some details and alternative sources and pricing. Also I will add links to the github stl’s for the printed parts (that seemed to help people for the HercuLien BOM). Now If I could only find a good and inexpensive source for CNC acrylic and aluminum parts for people. If anyone has a suggestion I am all ears.
@Seth_Messer So the parts I already ordered were not the correct one?
I’m confused now.
@Seth_Messer my invoice for the geared step motor shows this detail:
Nema17 40mm Stepper Gearmotor GSM002 $30.00 0.45KG
@Gus_Montoya what changed?
@Gus_Montoya no. You’re fine, you likely haven’t used the Google Sheets document yet and were using the original V2 excel document on github.
Ok, tomorrow my 2nd order of 2 will arrive. So I am crossing my fingers that I will be able to at least have the frame up.
Is there going to be a HercuLien Google Sheet coming soon?
I haven’t used Google Sheets. I assume only a select few will be able to make changes to it?
@bcrazycramer I will look into adding this in the future.
Thanks @Eclsnowman . On the HercuLien bom , is the excel spreadsheet the same as the PDF? The PDF shows V2. Almost done printing all the parts for the HercuLien.
@bcrazycramer I think so. I made some formatting changes a while back after some design changes. The excel is the master, use that first.
@Eclsnowman
So is this complete enough to start ordering? I have to run a comparison between this an V1 as I already ordered some the parts.
Thanks!
@Rick_Sollie you can use either the google sheets version or the xls version on @Eclsnowman 's github for eustathios v2. i’ve ordered all but my misumi parts from the google sheets doc.
2nd order came in, and it’s not correct. Will have to go back to look to varify. Anyone can tell me if returns to misumi is easy or painful?
@Gus_Montoya what was incorrect?
@Eclsnowman I think it’s my fault for messing up the order. I need to recheck, but at this time due to my recent circumstance I’ll be returning everything. I hope returns are not painful and long for misumi.
Since misumi parts are predrilled and cut to length I doubt you can return them.
