FireworksXY Just in time for the fireworks season,
@Thomas_Runge thank you, it compiles just fine now. I will try this out later tonight :slight_smile:
Hey guys, newbie here, is there a limit to how big the matrix is? what if you have 100x100 or something like that? Thanks.
@Fernando_Poe I’d be bringing a fusion reactor to power up that action.
I am having a problem with the program freezing after the first firework? any suggestions?
P.S. my matrix is 36x8 and I have already taken jason coon’s modifications to a larger matrix into account.
@Aren_Hibbing Yes, there were a few problems with it. Try this one http://pastebin.com/BcDcxmDe
If you don’t mind me asking, what are the changes? I took jason coon’s code he posted earlier and that is what I am using. I couldn’t really see off hand what the differences were. if it is the uint8_t being changed to uint16_t I already have that in here.
I suppose it is also worth mentioning that I have been getting a lot of help from Aaron Liddiment and he has made some changes to it as well, I just thought that if it was something I could easily track down I wouldn’t have to bug him as much :slight_smile:
As I recall, the original didn’t include support for a Serpentine arrangement, which I added. More importantly, I changed a line:
if( x > PIXEL_WIDTH || y > PIXEL_HEIGHT)
with:
if( x >= PIXEL_WIDTH || y >= PIXEL_HEIGHT)
Beyond that, I don’t recall.
I had already made thoes changes around the 4th of July when you guys were originally talking about it :slight_smile: thanks by the way.
As it turns out my problem was hardware related, I had been running a large matrix through the regulated power pins on the teensy, but since I had kept the brightness so low I never had any issues. As soon as I connected it to an external supply the problem went aways.
Thank you for your assistance in flushing out this problem :slight_smile:
how can you flip the image or can you
You could easily modify the function called “XY”, lines 41-49: https://gist.github.com/kriegsman/68929cbd1d6de4535b20#file-fireworksxy-ino-L41-L49
E.g. add this line between likes 42 and 43 to flip the X coordinate, therefore mirroring from left to right:
x = MODEL_WIDTH - x;
That should do it, I think.
You could do similar for y, if you wanted top-to-bottom flipping, but with MODEL_HEIGHT.
Let us know if that works out the way you intended!
