@Yves_BAZIN ok … so at the moment i´m search for the problem of this:
‘saveframe’ was not declared in this scope
@Stef_Weicks hello stupid of me
line 156 write saveframes(); instead of saveframe();
ha ok … i already wrote this so -> saveFrames(); // which didnt work too
@Stef_Weicks saveframes() not saveFrames() ;
@Yves_BAZIN
if i want to start the animations in jinx … the terminal calls:
Guru Meditation Error: Core 0 panic’ed (Unhandled debug exception)
Debug exception reason: Stack canary watchpoint triggered (FastLEDshowTask)
@Stef_Weicks do you see
the messages
Ready to record
Recordign starting ?
@Stef_Weicks try this
@Yves_BAZIN at starting the recording this error comes
@Yves_BAZIN now i get this …
WiFi connected.
IP address:
192.168.1.101
Card Mount Failed
Recording has started
Guru Meditation Error: Core 1 panic’ed (LoadProhibited)
. Exception was unhandled.
@Yves_BAZIN i checked my sd-card …is ok!
at the beginning / reset of the ESP the terminal call:
WiFi connected.
IP address:
192.168.1.101
Starting Artnet nbNeededUniverses:16
Ready to record…
@Stef_Weicks your SD card was not recognize that’s why you have an issue.
“Card Mount Failed”
@Stef_Weicks is ti working now ?
@Yves_BAZIN i tried it now with my second ESP32
card is ok … i checkt reading writing… did a new formated card in the slot … … then i took another sdslot. hm
IP address:
192.168.1.102
Card Mount Failed
@Stef_Weicks you see your card is not “mounted”
i don’t know why
@Stef_Weicks what do you mean you change sdslot ?
one moment i will check the old program is already working…@Yves_BAZIN
i have two different sd card slots … for my esps
old program works… so writing on the card should work! @Yves_BAZIN
@Yves_BAZIN missing/deleted image from Google+
@Stef_Weicks I did not change that part of the program. that is why i am confused. that your card is not recognize and not mounted
