I ordered 3 extra normal esp32 dev boards :D… Just in case
@Jeroen_van_Dorsten aha cool !!!
l am really curious to see your build
Testing power and data.
When its all ok. I will enclose all cables and connections inside small boxes.
@Jeroen_van_Dorsten impressive !! Courage for the rest.
thank you @Yves_BAZIN
@Yves_BAZIN will this " IC 74LVC245 8-bit Logic Level Shifter" do the same as the 74HC245? just to make sure :D. I can get those tommorow morning
I used a TXS0108E SPI-I2C-UART as levelshifter but it does not make it better.
Still got random white flashes after 5 strips. and i want them to dissapear before i go any further.
@Jeroen_van_Dorsten random flashes can come from different sources
If your strips are far from the board you should twist the data with the Braun’s wire to shield from interference
According to the datasheet the lvc should work.
Which version of the Fastled library are you using ?
@Yves_BAZIN the strips are connected 20 cm from the board.
I’m running Marc Merlins code, including libraries.
@Jeroen_van_Dorsten can I see your code ?
I mean the way you declare your strips
@Jeroen_van_Dorsten can you make a short movie of the defect you see
@Yves_BAZIN it’s exactly the same code. The only thing i changed is the size of the matrix. Mine is 300 x 16 x 1 instead of 64 x 64 x 16
The wiring i used to power the leds was to thin… now i’ll change it to 2.5mm wire i stead of 1 mm wire.
Had a small disapearance act last night… some cables went up in smoke
The data wires are cat6 . Still twisted but outside the outer shell.
When i get home ill take a screenshot of the matrix size what adjusted.
@Jeroen_van_Dorsten so the data wires would be ok
yes indeed be careful with the power wiring. I think the use of the level shifter will remove the load on the mcu and then remove the last artifacts
Wiring is a bitch…
When you are done with power and you still need to power the strips… and… data…
@Jeroen_van_Dorsten really neat
@Yves_BAZIN Last 3 strips keep flashing. Will put the level shifter in between…
@Jeroen_van_Dorsten whoua great !!! This really looks like cross wiring to me
I hope I will disappear with the level shifter!!
