Hey all. for some reason my LaserDRW isnt cutting from 'inside out'.
hows this? http://www.coreldraw.com/us/product/technical-suite/
@Bob_Damato Nah, the x8 link didn’t work. Tried it first. There is a link on the right hand side somewhere for x7 technical suite or something. It did work. Otherwise, I can put the files needed in my dropbox later (actually they’re already there, I just haven’t synced it yet).
Will coreldraw x8 work with our laser? Not the technical suite just x8? Ill actually buy it, I was able to get a discount code which makes it affordable.
I can’t comment directly, but I have a feeling that some others are using x8. I suggest either doing a quick search in the community or make a post & ask if it works. Someone will know for sure. I’d hazard that it will, provided it is not a home & student version, as there have been reports that home & student versions (not x8, but older x?).
edit: I found 1 post where someone was trying to get x8 to work. I tagged you into the post so you can see his reply to check if it works with x8.
Thanks again Yuusuf. For some reason I dont see a tag (im new to the google communities) but Ill still keep trying to figure it out. I know you cant use home and education as they dont support plugins. id be really surprised if x8 isnt supported but you never know! Ill keep looking for the post and do a little more digging too. Thanks :slight_smile:
bob
I’ll drop the link here so you can check in & follow it if need be. https://plus.google.com/+StevieRodgerCambyCrafts/posts/XhYFBN9XS6x
Hopefully Steve can get back to you & let you know if he managed to get it to work.
I have the plug-in working in my copy of X8.
