@Marc_MERLIN and @chad_steinglass Can you guys recap the solution? I’m not sure I completely understand what to do to avoid crosstalk. It sounds like the ground line is twisted together with the signal, but not electrically connected at all. Is that right?
sweet! I hope our vest cross paths on the playa.
@Sam_Guyer on mine the ground line is connected on both sides. I guess maybe I could disconnect it on the panel side, but I didn’t try that.
@Marc_MERLIN Sorry, maybe I’m being dense here …
Assuming I start with the simplest possible setup – three wires running to the strip (ground, power, and data) – what is the modification I need to make to protect the integrity of the data signal?
@Sam_Guyer if you have multiple data signal for parallel output, this is what I did:
- connect each signal line, along with a copy of ground from the ESP32 to a pair of wires on CAT-5 (1-2, 3-6, 4-5, 7-8). Connect that ground on the other side too (the signal too obviously)
- separately connect the high amp power supply to the ESP32 and the LEDs
- re-inject the ground and power into multiple places on the strip
http://marc.merlins.org/perso/arduino/post_2018-05-29_EDM-Party-Shirt-powered-with-FastLED_NeoMatrix-and-Adafruit_GFX_-plus-160Wh-10Ah-4S-worth-of-lipos.html
shows the wiring somewhat
@Sam_Guyer - as Marc is saying, in cat 5 cables, the wires inside are twisted pairs. I think you’re on the same page. Each twisted pair should be one signal and one ground. I think that’s it
For my quick solution since I didn’t happen to have a bunch of cat5 around, I just reduced the length of the signal wires significantly (from a couple feet to a couple of inches) and that solved it too.
And @Randal_B - hope to see you there too! I’ll be camped at 8:15&A
7:00 & Esplanade for me (dustfish), but it’s not like I’ll be there very much (because I take zillions of pictures everywhere for this: http://marc.merlins.org/perso/bm/2016/ ) . You’re more likely to see me roaming at night on the playa, and that’s how I’m planning to find @chad_steinglass too
Then, there is this guy (not fastled, but hella cool)
and this doesn’t suck either (still not fastled), but still not bad either
And these 2 losers, definitely is fastled
cool project by the way
can someone remind me (again) when the LED meetup is? i think its tuesday again? I always (and will probably) miss it
@Randal_B I think it starts Sunday and goes through the following Saturday night
Seriously though, I didn’t even know this was a thing. But I’ll join if we can figure it out!
@chad_steinglass I was going to say “monday to sunday, sunset to sunrise”
/ You can also try deep playa by the daft punk concert.
