Love the job, I might have to have a look through your image & settings & see if I can replicate this some time in the near future. I’d love to be able to do some wonderful carvings like this.
Wow, just watched your video of the engrave in action. I’ve definitely got to check through your settings. Much smoother motion than I’ve been getting. I’m for sure doing something wrong.
To be honest @Yuusuf_Sallahuddin_Y i think i just dropped lucky with my settings, if you have watched the video you can see a tiny engraving in the top left corner, that was my first ever attempt at carving, dropped the bmp resolution and this was the result, second attempt lol
@Mike_Grady Yeah, well your settings are working well, so I think whatever I did to my config file needs fixing
Great results for a 2nd attempt.
My actual config file only had one change, i decreased the current for the x axis motor to 0.3 because the movement was noisy and jerky
@Mike_Grady That may be what my actual issue is too… since I think I have it set at 0.5 for the x-axis motor. I will give that a test & see if it improves my performance
I’ll report back if that is the case once I give it a test.
ok, hope it works out for you
