can you do the slices for me and make the stl files ?
@Christoph_Derycker I can teach you how to do it, but I cannot do it all.
Tellen me when
Open up the .step file in fusion, and got to a part. I went to the frame piece, that is right underneath the body (Body Plate_Default). Click on it, It should turn blue as it is highlighted. left click on it and click “find in browser”. the part should either be highlighted in the “browser” menu or it will have a checkered blue line underneath it. It will be what is called a component. You can either click on the component file itself or open up all of the drop down expandable menus so and click on the body. Only do the latter if there are multiple bodies and one or a few are not shown (if it is not shown the light next to it will be off). Click on the part in the browser, left click again and then click “Save as STL.” Save it to your computer and then open up your slicer. Drop it into your slicer. You may have to reorientate it so that it is laying flat. Then you are able to print. Try to first figure out which parts can be printed without slicing. When you get to slicing, I will explain how you can go about that.
@brett_turnage could you help me on a Traxxas e/t maxx part ?
Are there any climber designs out there?
Cool! This would make a nice little crawler, may look into it a bit more after I finish my SCT!
