Hi @Terkel_Sorensen , of course remove the #include for OCTO in your case.
I quickly looked at your mods and do not see anything wrong. Can you be more specific about what is not working ?
@Terkel_Sorensen You forgot to add the data pin to your addleds !!
Should be… FastLED.addLeds<NEOPIXEL, DATA_PIN, RGB>(leds, NUM_LEDS);
Here’s a link to a post I made about that cube a while back…
https://plus.google.com/106626345342202981932/posts/RCnWduhk9Sr
I also includes a bunch of assembly pictures that may give you some idea of how to build one yourself if you are interested !
@JP_Roy I saw that post you wrote up - and the jig you made…
Promptly jumped on ebay - and found one built for $600… Yikes!!! hmm, my 8 year old knows how to solder…
@JP_Roy Adding the DATA_PIN gives me this error:
no matching function for call to ‘CFastLED::addLeds(CRGB [45], int)’
@Terkel_Sorensen Hard to say but just check your syntax carefully because that code works 100% !!
