@StephaneBUISSON
https://drive.google.com/open?id=0B5_IWI68ZqZTZzVyRHB1RlRLeTg
Is this hat you mean?
If not, please correct it
@StephaneBUISSON
+Peter van der Walt https://drive.google.com/open?id=0B5_IWI68ZqZTcF9BVUd4OHBUbUE
like this?
Can’t I directly connect WP to GND, that’s what I did when running with smoothie?
How can I calculate the laser PWM frequency?
+Peter van der Walt My configuration is same as yours and I already setup a laser fire pin.
But 3.3V pwm at LV side only giving me 3.6V PWm at HV siide. I measured all the voltage using DMM
HV -GND= 4.98V
LV-GND = 3.3V
LV1-GND = 3.3V (S1 COMMAND)
HV1-GND = 3.6V
https://drive.google.com/open?id=0B5_IWI68ZqZTbEp1TGVQOVFzWm8
This is my current connection please take a look at this
+Peter van der Walt
Did you check my connection, I want someone to make sure connection is correct except for wp through some protection, I will set up it as soon as I get a water flow sensor
How can I calculate the PWM freq?
+Peter van der Walt @StephaneBUISSON
I figured out what’s the problem.
10K pull up resistor on the HV side of logic level converter was too large in my case. I figured this out by doing,
I think this is due to the high input impedance of IN terminal
https://learn.sparkfun.com/tutorials/pull-up-resistors
So replaced 10K with 1k in logic level converter and I’m getting around 4.8V for S1(100% duty cycle)
Also ordered https://www.sparkfun.com/products/11771 and CD4050 .
I’ll check those too
good to know, thx
This is the level shifter I purchased
@Alex_Krause did you check the voltage b/w IN and GND?
+Peter van der Walt https://drive.google.com/folderview?id=0B5_IWI68ZqZTTlZyeEx0aDdmRGc&usp=drive_web
Sorry I didn’t see that request
https://drive.google.com/open?id=0B5_IWI68ZqZTMEllamlZX3lQWVE
Do I have to remove # from all the lines?
@Athul_S_Nair on my laser PSU? Not sure where you want me to check
@Alex_Krause yeah between IN and GND for S1 command
It’s labeled as 5v on the PSU but I haven’t thrown a multimeter on it yet
@Alex_Krause
can you check it?
In the idle state or under movement?
@Alex_Krause Idle state it would be 0, I want know the voltage when doing a job with full laser power(S1)
I can check but I have an analog machine don’t want to go above 15ma for the sake of keeping my tube operational
@15 ma I get 3.48v @10ma I get 3.63v @ 5ma I get 4.18v @ 1ma I get 4.78v… I have to test the output of the potentiometer to get my reading my terminals are covered in hot glue on the PSU
@Alex_Krause Those current readings are form your laser machine?
I mean current taken by the tube ?
@Athul_S_Nair it looks like my In pin is pulled Low for more power
