Hi peoples, I am trying to setup rs485 to my Huanyang VFD and have
In my case the firmware it’s compiled using the property CNC=1, the file that you downloaded from the site must be enough.
Lol I just looked at my previous post and it says pregnant style LCD. I meant pendant style LCD. Predictive text will get you.
I was wondering about that…, jeje, don’t worry.
the LCD is optional in the firmware-cnc
Hello again, been busy machining bifold doors for my studio and did not want to make these changes until that was finished. Well that’s finished and would like to get this sorted and would like some assistance.
The chinese boards have arrived and I have found some things that I’m not sure about and would like to check:
The ‘Example Config Options’ on the spindle-module page states ‘spindle.rx_pin =’ and ‘spindle.tx_pin =’. If this was RS485 should they not be A and B?
The ‘Spindle.dir_pin’ where does this go? I only have A, B and GND on my board.
http://smoothieware.org/spindle-module?s[]=spindle#example-config-options2
@Colin_Wildsmith1 Would you mind continuing this conversation in a new post on Reddit ? https://www.reddit.com/r/smoothieware/
G+ is dying soon, don’t want these conversations to die with it.
Hey Antonio, just came across this post looking for Modbud board and I was only able to find some 4 pins… and smoothie board demo has 5 pins according to this page : spindle-module [Smoothieware]
using something like you linked :
Can I just do this (not using the “DIR” PIN) ?
(smoothie <-> UART to 485)
3.3v – VCC
spindle.rx_pin P2.6 – RXD
spindle.tx_pin P2.4 – TXD
spindle.dir_pin P2.5 –
GND – GND
Yes, of course, in my case “dir” pin is not required. I suppose it could be used to enable “forward” or “backward” spindle’s direction. If you need both ways for the spindle, maybe you have to connect a button and wire to the vfd for each case. If I can remember, there are available screws on the vfd to define “forward” or “backward”. You have to use that screws and wire them to your button or buttons as you expected. By default, if you use this breakout, only a one way will be available. It depends how the spindle rotates. At the beginning of the tests using the breakout, If the “direction” that can be seen does not convince you, just exchange the “hot wires”. I can’t remember them, maybe they are labelled as “U,V,W” from the spindle to the vfd, just exchange two of them (in my case that was the solution), but, I can’t remember if it was U-W- W-U, or V-W W-V (just to give an example). Check this out and how the hot wires can be exchanged to be finally sure… hope it helps in some way… (The 4th wire (the green one as I remember) coming from the spindle is earth)…
I remember there is a program on the vfd that can define the direction of the spindle’s rotation, maybe you can wire the spindle to the vfd using u,v,w as you wish (first, validate if these entries are the hot wires), and after, change that program directly on the vfd. I could not remember the number of that program, check the vfd manual, and look for the related program and it’s possible values…
If the “dir” pin is not absolutely related with this, I don’t know which needs will require a tx-rx communications with the vfd in real time. Maybe the current rpm’s, the current consumption, or other parameters. Anyway… that breakout will not allow this case… (I suppose).
# Spindle
spindle.enable     true
# set this to false to disable the spindle module
spindle.type     modbus
# set the spindle type to modbus/RS485
spindle.vfd_type     huanyang
# set the VFD type, this is necessary because each inverter uses its own commands
spindle.rx_pin     2.6
# TX pin for the soft serial
spindle.tx_pin     2.4
# RX pin for the soft serial
spindle.dir_pin     nc
# RS485 is only half-duplex, so we need a pin to switch between sending and receiving
@Antonio_Hernandez Sorry, didnt got the reply notification ! I got everything hooked, but “M3 S10000” dosent do anything. Got an idea? Using the same module you listed above.
I tried to flip the RS+ and RS- and when I do, the RS485 RX/TX light are always on… so I guess it’s okay.
I don’t see the LED blinking when I send M3 or M5.
Here’s my full configuration of the VFD
Pd013=8; reset up the inverter.
Pd001=0 ; #1 Knob/Analog, #2 – RS485
Pd002=2 ; #1 Knob/Analog, #2 – RS485
Pd004=400; Base Frequency;
Pd005=400; Operating Frequency
Pd003=400; Main Frequency (need to do 4 and 5 first)
Pd008=110;Voltage to 110v
Pd011=120; Min Frequency for Air Cooled (7200RPM)
Pd014=15; 15s accell.
Pd015=15; 15s decel.
Pd041=3; 3 is suggested by the other file provided.
Pd070=1; 0-5V.
Pd072=400; Low Analog Frequency
--Non?--Pd073=120; Min Frequency for Air Cooled (7200RPM) for 0-5V PWM
Pd120=120; Stale Protection (120%).
Pd141=110; Max Voltage
Pd142=11; Spindle Max Current is 12A, but I set to 11A.
Pd143=2 ; 2 poles;
Pd144=3000 (Motor Max RPM, 24000@400Hz = 3000@50HZ)
PD163: 1 ; (Communication address: 1)
PD164: 1 ; (Communication Baud Rate: 9600)
PD165: 3 ; (Communication Data Method: 8N1 RTU)
Pd176=1
and my full smoothieware configuration, runnning on the CNC Build version: edge-6a3b837
# Smoothieboard configuration file, see http://smoothieware.org/configuring-smoothie
# NOTE Lines must not exceed 132 characters, and '#' characters mean what follows is ignored
## Robot module configurations : general handling of movement G-codes and slicing into moves
# Basic motion configuration
default_feed_rate                            3000             # Default speed (mm/minute) for G1/G2/G3 moves
default_seek_rate                            3000             # Default speed (mm/minute) for G0 moves
mm_per_arc_segment                           0.4             # Fixed length for line segments that divide arcs, 0 to disable
#mm_per_line_segment                         5                # Cut lines into segments this size
mm_max_arc_error                             0.01             # The maximum error for line segments that divide arcs 0 to disable
                                                              # note it is invalid for both the above be 0
                                                              # if both are used, will use largest segment length based on radius
# Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
# See http://smoothieware.org/stepper-motors
alpha_steps_per_mm                           800              # Steps per mm for alpha ( X ) stepper
beta_steps_per_mm                            800              # Steps per mm for beta ( Y ) stepper
gamma_steps_per_mm                           2004             # Steps per mm for gamma stepper (2004 = 1204 Ballscrew, 1000 = T8 Leadscrew 2mm 4start)
# Planner module configuration : Look-ahead and acceleration configuration
# See http://smoothieware.org/motion-control
acceleration                                 1000             # Acceleration in mm/second/second.
z_acceleration                               600              # Acceleration for Z only moves in mm/s^2, 0 uses acceleration which is the default. DO NOT SET ON A DELTA
junction_deviation                           0.03             # See http://smoothieware.org/motion-control#junction-deviation
#z_junction_deviation                        0.0              # For Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves DO NOT SET ON A DELTA
# Stepper module configuration
# Pins are defined as  ports, and pin numbers, appending "!" to the number will invert a pin
# See http://smoothieware.org/pin-configuration and http://smoothieware.org/pinout
alpha_step_pin                               2.1              # Pin for alpha stepper step signal
alpha_dir_pin                                0.11!            # Pin for alpha stepper direction, add '!' to reverse direction
alpha_en_pin                                 0.10             # Pin for alpha enable pin
alpha_current                                0.1              # Unused stepper motor current
alpha_max_rate                               8000             # Maximum rate in mm/min
x_axis_max_speed                             8000             # Maximum speed in mm/min
beta_step_pin                                2.2              # Pin for beta stepper step signal
beta_dir_pin                                 0.20             # Pin for beta stepper direction, add '!' to reverse direction
beta_en_pin                                  0.19             # Pin for beta enable
beta_current                                 1.5              # X stepper motor current
beta_max_rate                                8000             # Maxmimum rate in mm/min
y_axis_max_speed                             8000             # Maximum speed in mm/min
gamma_step_pin                               2.8              # Pin for gamma stepper step signal
gamma_dir_pin                                2.13!            # Pin for gamma stepper direction, add '!' to reverse direction
gamma_en_pin                                 4.29             # Pin for gamma enable
gamma_current                                1.5              # Y stepper motor current
gamma_max_rate                               2000             # Maximum rate in mm/min
z_axis_max_speed                             2000             # Maximum speed in mm/min (was 30000)
## Switch modules
# See http://smoothieware.org/switch
# Switch module for fan control
switch.fan.enable                            false            # Enable this module
switch.fan.input_on_command                  M106             # Command that will turn this switch on
switch.fan.input_off_command                 M107             # Command that will turn this switch off
switch.fan.output_pin                        2.6              # Pin this module controls
switch.fan.output_type                       pwm              # PWM output settable with S parameter in the input_on_comand
#switch.fan.max_pwm                          255              # Set max pwm for the pin default is 255
#switch.misc.enable                          true             # Enable this module
#switch.misc.input_on_command                M42              # Command that will turn this switch on
#switch.misc.input_off_command               M43              # Command that will turn this switch off
#switch.misc.output_pin                      2.4              # Pin this module controls
#switch.misc.output_type                     digital          # Digital means this is just an on or off pin
## Endstops
# See http://smoothieware.org/endstops
endstops_enable                              true             # The endstop module is enabled by default and can be disabled here
#corexy_homing                               false            # Set to true if homing on a hbot or corexy
alpha_min_endstop                            1.24^            # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop                           1.25^            # Pin to read max endstop, uncomment this and comment the above if using max endstops
alpha_homing_direction                       home_to_min      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
alpha_min                                    0                # This gets loaded as the current position after homing when home_to_min is set
alpha_max                                    650              # This gets loaded as the current position after homing when home_to_max is set
beta_min_endstop                             1.26^            # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#beta_max_endstop                            1.27^            # Pin to read max endstop, uncomment this and comment the above if using max endstops
beta_homing_direction                        home_to_min      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
beta_min                                     0                # This gets loaded as the current position after homing when home_to_min is set
beta_max                                     415              # This gets loaded as the current position after homing when home_to_max is set
#--PROBE-- #gamma_min_endstop                           1.28^ # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
gamma_max_endstop                            1.29^            # Pin to read max endstop, uncomment this and comment the above if using max endstops
gamma_homing_direction                       home_to_max      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
gamma_min                                    0              # This gets loaded as the current position after homing when home_to_min is set
gamma_max                                    137              # This gets loaded as the current position after homing when home_to_max is set
alpha_max_travel                             670              # Max travel in mm for alpha/X axis when homing
beta_max_travel                              435              # Max travel in mm for beta/Y axis when homing
gamma_max_travel                             157              # Max travel in mm for gamma/Z axis when homing
soft_endstop.enable         true         # Enable soft endstops
soft_endstop.x_min          0            # Minimum X position
soft_endstop.x_max          650          # Maximum X position
soft_endstop.y_min          0            # Minimum Y position
soft_endstop.y_max          415          # Maximum Y position
soft_endstop.z_min          0            # Minimum Z position
soft_endstop.z_max          137          # Maximum Z position
soft_endstop.halt           true         # Whether to issue a HALT state when hitting a soft endstop (if false, will just ignore commands that would exceed the limit)
# Optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable                          false            # Set to true to enable X min and max limit switches
#beta_limit_enable                           false            # Set to true to enable Y min and max limit switches
#gamma_limit_enable                          false            # Set to true to enable Z min and max limit switches
# Endstops home at their fast feedrate first, then once the endstop is found they home again at their slow feedrate for accuracy
alpha_fast_homing_rate_mm_s                  50               # Alpha/X fast homing feedrate in mm/second
alpha_slow_homing_rate_mm_s                  25               # Alpha/X slow homing feedrate in mm/second
beta_fast_homing_rate_mm_s                   50               # Beta/Y  fast homing feedrate in mm/second
beta_slow_homing_rate_mm_s                   25               # Beta/Y  slow homing feedrate in mm/second
gamma_fast_homing_rate_mm_s                  50               # Gamma/Z fast homing feedrate in mm/second
gamma_slow_homing_rate_mm_s                  25               # Gamma/Z slow homing feedrate in mm/second
alpha_homing_retract_mm                      2                # Distance to retract from the endstop after it is hit for alpha/X
beta_homing_retract_mm                       2                # Distance to retract from the endstop after it is hit for beta/Y
gamma_homing_retract_mm                      2                # Distance to retract from the endstop after it is hit for gamma/Z
# Optional order in which axis will home, default is they all home at the same time,
# If this is set it will force each axis to home one at a time in the specified order
#homing_order                                 XYZ              # X axis followed by Y then Z last
#move_to_origin_after_home                    false            # Move XY to 0,0 after homing
#endstop_debounce_count                       100              # Uncomment if you get noise on your endstops, default is 100
#endstop_debounce_ms                          1                # Uncomment if you get noise on your endstops, default is 1 millisecond debounce
home_z_first                                  true             # Uncomment and set to true to home the Z first, otherwise Z homes after XY
# End of endstop config
# Delete the above endstop section and uncomment next line and copy and edit Snippets/abc-endstop.config file to enable endstops for ABC axis
#include abc-endstop.config
## Z-probe
# See http://smoothieware.org/zprobe
zprobe.enable                                true           # Set to true to enable a zprobe
zprobe.probe_pin                             1.28!^          # Pin probe is attached to, if NC remove the !
zprobe.slow_feedrate                         5               # Mm/sec probe feed rate
#zprobe.debounce_ms                          1               # Set if noisy
zprobe.fast_feedrate                         100             # Move feedrate mm/sec
zprobe.probe_height                          5               # How much above bed to start probe
gamma_min_endstop                            nc              # Normally 1.28. Change to nc to prevent conflict,
## Panel
# See http://smoothieware.org/panel
# Please find your panel on the wiki and copy/paste the right configuration here
panel.enable                                 true             # Set to true to enable the panel code
# Example for reprap discount GLCD
# on glcd EXP1 is to left and EXP2 is to right, pin 1 is bottom left, pin 2 is top left etc.
# +5v is EXP1 pin 10, Gnd is EXP1 pin 9
panel.lcd                                   reprap_discount_glcd     #
panel.spi_channel                           0                 # SPI channel to use  ; GLCD EXP1 Pins 3,5 (MOSI, SCLK)
panel.spi_cs_pin                            0.16              # SPI chip select     ; GLCD EXP1 Pin 4
panel.encoder_a_pin                         3.25!^            # Encoder pin         ; GLCD EXP2 Pin 3
panel.encoder_b_pin                         3.26!^            # Encoder pin         ; GLCD EXP2 Pin 5
panel.click_button_pin                      1.30!^            # Click button        ; GLCD EXP1 Pin 2
panel.buzz_pin                              1.31              # Pin for buzzer      ; GLCD EXP1 Pin 1
panel.back_button_pin                       2.11!^            # Back button         ; GLCD EXP2 Pin 8
panel.menu_offset                            0                 # Some panels will need 1 here
panel.alpha_jog_feedrate                     3000              # X jogging feedrate in mm/min
panel.beta_jog_feedrate                      3000              # Y jogging feedrate in mm/min
panel.gamma_jog_feedrate                     200               # Z jogging feedrate in mm/min
panel.hotend_temperature                     185               # Temp to set hotend when preheat is selected
panel.bed_temperature                        60                # Temp to set bed when preheat is selected
## Custom menus : Example of a custom menu entry, which will show up in the Custom entry.
# NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
#custom_menu.power_on.enable                true              #
#custom_menu.power_on.name                  Power_on          #
#custom_menu.power_on.command               M80               #
#custom_menu.power_off.enable               true              #
#custom_menu.power_off.name                 Power_off         #
#custom_menu.power_off.command              M81               #
## Network settings
# See http://smoothieware.org/network
network.enable                               false            # Enable the ethernet network services
network.webserver.enable                     true             # Enable the webserver
network.telnet.enable                        true             # Enable the telnet server
network.ip_address                           auto             # Use dhcp to get ip address
# Uncomment the 3 below to manually setup ip address
#network.ip_address                           192.168.3.222   # The IP address
#network.ip_mask                              255.255.255.0   # The ip mask
#network.ip_gateway                           192.168.3.1     # The gateway address
#network.mac_override                         xx.xx.xx.xx.xx.xx  # Override the mac address, only do this if you have a conflict
## System configuration
# Serial communications configuration ( baud rate defaults to 9600 if undefined )
# For communication over the UART port, *not* the USB/Serial port
#uart0.baud_rate                              115200           # Baud rate for the default hardware ( UART ) serial port
second_usb_serial_enable                     false            # This enables a second USB serial port
#leds_disable                                true             # Disable using leds after config loaded
#play_led_disable                            true             # Disable the play led
# Kill button maybe assigned to a different pin, set to the onboard pin by default
# See http://smoothieware.org/killbutton
kill_button_enable                           true             # Set to true to enable a kill button
kill_button_pin                              0.23            # Kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
kill_button_toggle_enable                    true             # allows for latching estop button
unkill_enable                                false            # do not unkill when button held or released
#msd_disable                                 false            # Disable the MSD (USB SDCARD), see http://smoothieware.org/troubleshooting#disable-msd
#dfu_enable                                  false            # For linux developers, set to true to enable DFU
# Only needed on a smoothieboard
# See http://smoothieware.org/currentcontrol
#currentcontrol_module_enable                 true             # Control stepper motor current via the configuration file
#GRBL for CNC
grbl_mode true
#spindle configuration
spindle.enable       true # set this to false to disable the spindle module
spindle.type         modbus # set the spindle type to modbus/RS485
spindle.vfd_type     huanyang # set the VFD type, this is necessary because each inverter uses its own commands
spindle.rx_pin       2.6 # TX pin for the soft serial
spindle.tx_pin       2.4 # RX pin for the soft serial
spindle.dir_pin      nc
Got it working… apparently, I can’t have the LCD and VFD as I need to use the 3.3V and GND at the same place :stuck_out_tongue:
Ok. That sounds great !. Really good to see that the rs-485 module works as expected.
it’s a little offset as you said (like 7890 instant of 8000), but all good for me !
While it’s working with a minimal error over rpm’s, I would like to think… it’s alright…
