I can't get Chilipeppr to connect today. Worked fine yesterday. Jason sever appears fine.
New cable-no luck. Hooking up the gShield board.
Thanks for the help.
@David_Anderson it does look like I introduced a bug for TinyG original v8 users over the weekend. I was asking for TinyG to start auto reporting “posa”:true information in the status report. That worked fine in G2, but seemed to mess up original TinyG’s. My apologies. I think that was why you were seeing a problem. Please hit reload because I fixed it.
Hey John, all working again. Thanks for the help and fixing the problem!
You should report that issue on the tinyg github page… which firmware versions are affected?
Thank-you. Works great. Now to solve my original problem which may be the same as: https://plus.google.com/102751366649234615705
@David_Anderson Bill was in need of a FW upgrade. What FW build are you running? If not 440.14, then you need one as well.
What OS do you use on your PC?
I’m running Win7 on my PC. I have not checked the Tinyg firmware but will the next time I’m using it.
