Hi Guys so i started working on trying to get all the bubbles out my tube and what i found to work as losing the tube clamps rotating the tube until the outlet pipe was straight up no more bubbles in the tube anywere hope this helps.
Dennis
Dennis
@Dennis_Fuente Thanks for sharing that Dennis. I checked my tube earlier & it seems that no bubbles anymore for me, but if I get them again I’ll try that. Also, if you have your water tank & pump higher than the tube, it will gravity feed into the tube, so when you turn it off/not using it the bubbles won’t reappear in the tube. On top of that, I have my outlet tube submerged into the water reservoir as well, so it doesn’t create bubbles with the water splashing in.
