@Dimitris_Prokos The movement is caused by the x axis, however you cannot see it in a signal layer as it is probably .05mm or less per event. However this error compounds and as you move up in the Z axis you can start to see the distance add up.
Edit ( it is almost impossible for this type of movement to occur in the z axis without the device falling apart)
