@Joe_Fochs yeah, that four pin din is what I was trying to avoid. I’ll start looking for an inexpensive PSU. Thanks for your help!
@Joe_Fochs I think I’ve found a 4-Pin mini din through Mouser that has a current rating at 7.5! Yay!
@K1111
7.5 Amps at how many volts???
@K1111
…what are the specs on your heat bed?
I’m out, so I don’t have all the specs right now. I do know it’s 12V. It’s a PrintrBot branded bed.
So until my connector arrives to properly wire the bed to the controller, I went ahead and wired up the temp controller I have on hand. It seems to work pretty well. It swings about a degree in each direction. I’d still like to figure out how to wire in some sort of trigger for on/off so that when either the fan turns off or when the Z-max stop is triggered the bed turns off.
