M4 & M5 Pins Not Working
Commenting those two lines will cause the driver not to work.
Can you send me via email your config file as it is now ?
So I tried the new config again because realized I hadn’t changed the baudrate before testing today (we have another printer that uses a different baudrate) so both motors are working!! Great! Unfortunately, the heaters still do not work. T0 is registering the temperature is set but is not heating and T1 is not registering at all.
Can you give me the result of the M105 or @M105 command after you ask both heaters to heat up ?
Thank you.
The result of M105 is: ok T:23.7 /175.0 @255 T1:24.0 /0.0 @0 B:inf /0.0 @0
