My X7 DSP upgrade.
It was nothing special, it wires directly to AC power, the ammeter and the dsp. Did you need the pinout of the power supply / connections to the dsp?
that would help thanks. i thought i had found everthing i needed to do this upgrade but now that its all in front of me i may be in over my head
Okay, let me put something together.
thanks man that would be awesome
Connectors as pictured left to right
4 pin
Grey wire to ammeter and tube
Wire to machine ground post
AC in
AC in
6 pin
ENABLE A – }
ENABLE B – } jumper these two or add generic safety switch.
TTL (old test fire button) – to dsp TTL screw
GROUND (old side a of pot) – to dsp GROUND screw
PWM (old center of pot) – to dsp PWM screw
+5v (old side b of pot) – no connection
4 pin
No connections. Untrusted. Supplied power to old Moshi board.
*So all you should need is 3 wires and a jumper. *
FYI water protection (WP) – connect your pump pressure switch between WP and GROUND.
awesome thank you man this is exactly what i needed
Oh btw on Laser2 jumper WP and ground or it will throw a water protection error at you. If you want to use the lid switch, it connects to IN1 and GROUND. I have it on a keyswitch myself so the kids can’t fire the laser.
Good idea with the key switch I hope to get started actually putting this all back together as soon as I’m off work tomorrow thank you very much
Anytime!
@Jerry_Martin Like this?
ok sorry for all the questions but on the first pin on the 4 pin you mean 2 separate wires correct the grey wire running to the tube and then another running to the ammeter
Both are grounds. Leftmost pin to the meter (if equipped). The other meter pin goes to the tube.
The second pin goes to the grounding post in the back of the machine or similar.
