@Jonathan_Davis_Leo_L could you by chance point me in a direction for end stops I will require and how you hooked them up please? And I also had to order the stepper drivers and SD card (but I have many SD cards so it is no biggie). I know Ray mentioned something about end stops but didn’t go into detail. Thank you in advance!
@Kelly_S Ray is still devloping the instructions on how to install the end stops, but the cheapest ones i found were part of a ardunio laser engraving kit on ebay.
@Jonathan_Davis_Leo_L did you use something similar to these?
@Kelly_S I also ordered the RJ45 module for connecting to Laserweb, probaby is not a must, but nice to get it.
http://www.ebay.co.uk/itm/302056710156?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have that module and my display waiting already
@Kelly_S I think would be better if you go to this type of switches for mounting in the rails, with the others mounting in a board, it is gonna be more difficult put them in place.
@Antonio_Garcia thanks, but I guess those will not be required for my application.
@Antonio_Garcia the plugin controls are dropping to the system status/taskbar in the lower right of your screen down by the clock. You’ll see a little upward pointing triangle and if you click that you’ll see the hidden system objects like your printer etc - and the plugin for Corel. You don’t need to exit & reload Corel each time you send something to the laser.
