@Eric_LeFort Im using Cura, but I don’t see any settings for adjusting that
@Rigo_Arevalo , could you enter M212 and tell us the output from your printer?
@Rigo_Arevalo OK then. I had a reprap prusa 2. IF your motor skipp when your belt is tight check the motor controller on the board. It’s sounds like the motor got to low power. I’m not shure what motherboard the printer you havet are using?
Printrbot revision F
Folks I did the print again and realized what was happening. Since It was the kit and I assembled it, I routed the cable facing down (from the extruder) instead of out. At the end of the prints when it was tall it was snagging the corner and messing up the alignments … =/ I reattached the cable facing out and now I’m set !
