Yup. I think I’ll use an atx supply, so I’ll still a hole in the back for the wires.
The PSU bracket is available on Thingiverse.
btw, I’d hop into reprap on http://irc.freenode.net (webchat at http://webchat.freenode.net) if you haven’t already. Wealth of info and experience in there.
Oh thanks man!!!
So people on the reprap irc said to use shelving board. That chipboard that’s coated in white melamine. What do you guys think? They said to use 20mm
Sounds fine. Shelving board is either chipboard or mdf, depending on where you get it from.
Also, I highly recommend hanging out in the reprap irc channel, you’ll learn a lot.
Yea I will it seems really good. I’ll try to get chipboard as they said it’s better. You don’t think that 20mm is too thick, do you?
“Too thick” is only defined by how your parts are printed. If you are using the JSCAD sources to generate your own parts, then, well, you could go however thick as you can get printed. I’m usually in reprap myself, but have been busy lately.
