never had the trial error, just the cd-key one
and it is blocked in the firewall and all over the place
Yeah I just uninstalled & reinstalled to test for another user & I end up getting the CD-key error too. Looking at an X7 Technical Suite/keygen version shortly to see if it works. In the process of downloading the 1.5gb “trial” version now.
Okay, got the X7 Tech Suite working with CorelLaser. Instructions here:
Okay, I’ve found another way to get it to work with Corel Draw Technical Suite x7 & a different keygen. Currently working.
Get the keygen here:
http://free.appnee.com/corel-all-products-universal-keygen-by-x-force-for-win-32-64/
I used the first download link available (from zippyshare).
Then get Corel Draw Technical Suite x7 trial (1.5 gb) here:
I chose 64 bit version.
- Install Corel Draw x7, making sure to untick the option for “auto-update”, open the keygen when asked for serial number.
- Generate Serial Number, keep the keygen open.
- Upon completion of install, open Corel Draw. It will prompt you for activation. Choose other activation, & phone Corel. Then type the Installation Code into the open keygen (in correct space, making sure to put the -'s).
- Generate Activation Code (make sure you don’t generate serial again).
Should be activated then.
Then, you want to block it in Windows Firewall. I use Windows 10, so instructions may differ for your windows, but you want to go into Windows Firewall with Advanced Security.
- Go to Outbound Rules
- Create new rule, type program (you will do this twice).
- Point to the following 2 programs:
C:\Program Files\Corel\CorelDRAW Technical Suite X7\Programs64\CorelDRW.exe
C:\Program Files\Corel\CorelDRAW Technical Suite X7\Programs64\DIM.exe
- Select Block from the list of options for what to do with network connections.
- Name the rules as something like Corel Draw Block & Corel DIM Block.
- Now it shouldn’t connect to Corel to verify.
Did the problem with the invalid serial for X5 get corrected? i am still unable to figure this one out.
@joe_ab_thedude No, doesn’t work anymore. Not sure why either. I switched to x7. See my post here in the comments before your comment.
Thanks for this Yuusuf!
@Adam_J I think this version may longer be hosted or working. I ended up having to switch to x7, although am no longer using that as I have upgraded to smoothie/laserweb.
Yeah, I’m using your link to x7 too. Had trouble with X5 crashing all the time, X7 is working fine for now, thanks!
what is the best version or coral to use?
@joe_ab_thedude Any version that works really. I used CorelDraw 12, x5 & x7 successfully. Others have used x8 also & I think some other variants. This version of x5 linked here doesn’t work with the keygen anymore.
what is the trick to activate X8? Keeps asking to create an account to activate.i did the same firewall permissions as X7.
@joe_ab_thedude I never tried anything above x7, so can’t say. Maybe someone else has tried & knows.
x8 works as well but I only had the trial version, and only for about a day before I went to x7 again
can someone host the X7 keygen??
for some reason i can not download it from the site.
Thanks!!
when I attempt to open the Keygen it flags as a potential trojan…any info on this?
@Brandon_Martabano Yes, it flags it for everyone. I have no idea what is actually in the keygen, so use at your own risk. But from my experience, every keygen I’ve ever used (since prior to year 2000) has always flagged as a virus of some kind.
Ok thank you! Any one report any problems after using it? Im very hopeful this will be the resolution to my problem
@Brandon_Martabano Not that I’m aware of. I used it for a while & then switched up to corel x7, so I can’t talk about long term usage, but for the period I used it I had no issues with it.
@Yuusuf_Sallahuddin_Y The Dropbox link is not working have the files been deleted?
@Ted_Schaeffer Yeah, Dropbox links are gone now. I have CorelDraw x7 hosted on OneDrive.
You’ll need:
CorelDrawTechnicalSuiteX7 file (https://1drv.ms/u/s!AqT6a-6Vl15Nh7ltP5ugiVeTWu62Lg)
Then activator:
AppNee.com.Corel.x5-x9.All.Products.Universal.Keygen.7z (https://1drv.ms/u/s!AqT6a-6Vl15Nh7lryA4zpKIb9vWGBw)
Then you will also need CorelLaser 2013.02 (fifth in list):
http://www.lcshenhuilaser.com/download.html
This article provides details for how to activate etc: http://free.appnee.com/corel-videostudio-pro-ultimate-x7-x8-universal-keygen-for-win/
Hope that helps.
