Stef Weicks hello Apparently we exceed th elenght of you discussion thread :) How
my goodness you travel around a lot!! hopefully not for work? :slight_smile:
it“s absolutely no problem!
@Stef_Weicks I was in Frankfort for work yesterday meeting in Lisbon this morning and now week end !!! Drinks music and …
wow … seems to be a nice job you have … i think mine is boring to this :wink:
so rock the house… wish you a nice partynight !!!
@Stef_Weicks not that fun always lol railway doesn’t rime with fancy and party but now it’s week end
yes i totally agree! haha
at work the pain and at home the fun! hopefully you have some party animals around!!
my last trip to Lisboa was 2009 … but i think i met the wrong people to make a nice party
@Stef_Weicks here fancy rooftops and then tapas and clubs until 6am
I hope you have pre-sleeped to get through this. lol
@Stef_Weicks try this
and show me the serial output
Time: 14:36:32
Day Relay HIGH
SD-Card
time on
Time: 14:36:32
Day Relay HIGH
SD-Card
time on
Starting Artnet nbNeededUniverses:16
Trying to connect Blynk…
[34104]
__ __
/ _ )/ / / /
/ _ / / // / _ / '/
/_//</i>, /////</i>
/ v0.5.3 on ESP32
Give Blynk a Github star! => https://github.com/blynkkk/blynk-library
[34117] Connecting to blynk-cloud.com:80
Wifi Connected
[37699] Login timeout
Time: 14:36:38
Day Relay HIGH
SD-Card
time on
[40644]
__ __
/ _ )/ / / /
/ _ / / // / _ / '/
/_//</i>, /////</i>
/ v0.5.3 on ESP32
[40654] Connecting to blynk-cloud.com:80
trying to connect to the Wifi…E (49401) phy_init: failed to allocate memory for RF calibration data
abort() was called at PC 0x400e8130 on core 0
Backtrace: 0x400949f4:0x3ffe12a0 0x40094bf7:0x3ffe12c0 0x400e8130:0x3ffe12e0 0x4011b99a:0x3ffe1310 0x4011ba34:0x3ffe1340 0x4011bd1e:0x3ffe1370 0x4011be97:0x3ffe13a0 0x4008daa0:0x3ffe13c0
Rebooting…
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:952
load:0x40078000,len:6084
load:0x40080000,len:7936
entry 0x40080310
RTC is older than compile time! (Updating DateTime)
Number of files already stored:25
Num Pixels: 2560
[145] Disconnected
Time: 14:36:38
Day Relay HIGH
SD-Card
time on
6
Time: 14:36:38
Day Relay HIGH
hello @Yves_BAZIN ! i hope you are fine … are you already back from your trip?
@Stef_Weicks no still in Lisbon. Going to the beach. I looked at the code once my Advil had kicked in.
I don’t know exactly why the change of behaviour of the code. But I have rearrange some lines to make the debugging easier
oh yes, these are the bad things after a good party night.
…but in the Atlantic it will still be too cold to swim.
hm … i see … super method you did with the time-switch … i also will need this in an other program.
@Stef_Weicks good :wink: then I am not too roasted. I will see if a cold swim will help me
good luck! :smiley:
@Stef_Weicks did it worked
Unfortunately i didnĀ“t got it… but from my understanding it should do what we want … i tried some wifistatus=true and false; in the loop too … i thought maybe the wificonnect should only be executed if it is necessary?? …so no while(1) ? but i donĀ“t know …if that works…
or what do you think of a deep-sleep mode … instead of a wifi off?
@Stef_Weicks can you show me the serial output?
If you go deep-sleep nothing will work at all
the serial output is the same from above. it tries to connect … blynk connects for about 1 or max two seconds! …than its an abrupt disconnection … and tries again … and that runs in a loop.
if its time to sleep the whole thing should be ā€œoffā€ therefore it doesnĀ“t matter the controller is running or not… i know i could also do thist with a timeclock but I would prefer it if it switch only off the wifi (because of the ā€œradiation, electro-smogā€).
Can u send it to me anyway because I have changed something in the debug I would like to see the results
ok one moment
