This is my PSU what is the best way to convert it to smoothie
So guys i have had a setback for a reason so far undiscovered the smoothie board won’t boot up only one led lights up and i can’t even discover it through USB, so now double checking all of my circutry the board was working perfectly i did smoe test cut’s no problem then shut the system down for the night and now it won’t boot
@Dennis_Fuente ​ make sure the SD is fully inserted and making good contact
Hi Ariel Thanks for the response i did check the SD card and even installed a new one also did a fresh firmware install still no luck board won’t boot i think something went down on the board it sucks because the board was not cheap i only get the first LED to light up and that’s as far as it go’s disconnected everything took the boards out of the machine and just ran the usb to it still teh same i looked to the smoothie trouble tree found no help with anything on there so i will keep looking it could be the clock but i think the board is toast
Well the board is gone nothing has worked to get it to boot i have to get another board not going with a $150.00 smoothie again
@Dennis_Fuente ​ did you ask the manufacturer for help?
Well I thought about that but coming from an electronic background I know what is going be said and asked then around we go
