Version 4.0.721 Frontend & 4.0.63 Backend for Windows and OSX are out.
@Ariel_Yahni_UniKpty Test Video (video fixed)
@Jim_Fong ​ would you say it’s a good outcome? Is the sizing correct?
@Todd_Fleming ​ look above
@Ariel_Yahni_UniKpty size is exact. I noticed YouTube messed up the video upload. Re-uploading video again.
The rotary I’m using is from my mill/gantry with high reduction ratio. Nema23 motor. The stepper driver doesn’t have enough current to properly drive this motor. I needed to run this at a slow 10mm/sec cutting rate. Good enough to test for now.
As far as sizing, i tested by making a vertical line 78mm in length. The piece of wood is 25mm diameter. The laser cut a line one full revolution perfectly.
