@Wolfmanjm I’m using code from laserweb are you typing in commands from pronterface or some other interface? I have defined the homing procedure per the readme and still unable to get homing G28 to work properly… I have to give up testing for the evening I have BBQ in the smoker I am feeding 10 people at work tomorrow for our last 13 hour shift before the holiday. I will try to pick up where I left off tomorrow assuming that my ole lady will let me
I connect direct to smoothie, or use bCNC laserweb does not run on that version of debian I have, which is why i am updating it. not sure if laserweb allows commands? anyway post your config somewhere i’ll see why homing doesn’t work for you
oh @Alex_Krause G28 is not home on a cnc build, it is $H or G28.2, G28 is goto predefined park position. The binary I put up is a CNC build which is what laser users should be using. You were probably using the 3d printer build if G28 was homing for you before.
@Wolfmanjm just completed a successful test.
