3D Printed vehicle project. Wow.
Originally shared by Michael Curry
Update on my 3d printed vehicle project. Finished building the Rear Suspension test rig today. Next up is load testing, then on to designing some CV joints and driveshafts.
If you like this then you should check out the Open RC community here on G+.
Might be worth looking into: http://en.wikipedia.org/wiki/Constant-velocity_joint#Thompson_coupling
So you can use roller bearings only and reduce stress on the rest of the joint. At the expense of more complexity.
