3D-printing a Vase in the basement
Looks like 2 vases, with a gigantic wall gap.
0 infill is the bet ill make.
What extruder guide are you using. It looks different than the standard mendelmax 2. I like the look. Is it on thingivese?
I have one of the mendelmax 2 betas, so i have an earlier guide. I don’t have any issues with it. You van download that version from makers tool works homepage. They have the .stls on dropbox.
@ThantiK @Matthew_Q I have 0 infill and two shells, with the spiral setting in Slic3r. It took almost 36 hours to print a 250 mm high vase.
I thought you could only have a single wall for spiral. How is the nozzle coming back to do the second wall. If you use 1 shell , your time will probably drop considerably as your Z is probably going crazy. I thought slicer only allowed spiral for a single perimeter.
