(3rd question today!)
I keep getting little burnt chunks in the print, how does this happen?
Is the printer over extruding?
What can I do to fix this
This same problem was posted a day or two ago. Clean your nozzle, you probably have bits of filament stuck to it.
@Adam_Steinmark I already cleaned it, and cleaned every time before each print. And in every single print I get this.
@Nathan_Walkner Yeah, I kinda guessed that. What would I do to fix this?
@Nicholas_ScarabCoder
Could it be that your nozzle is leaking a bit? Everything thight?
@Rien_Stouten You mean extruding when it is not supposed to? You might be right, I think I’ll take it off and makes sure everything is tight.
@Nathan_Walkner I don’t think that is the problem. Even with simple prints (like boxes) it will have this problem.
@Nathan_Walkner Nah, I have my temperature at 230C, which is actually less then what people would normally use for ABS.
Link to his new post with picture https://plus.google.com/+NicholasHarris/posts/Wn4dQVLBLha
