4800 LEDS. Mirrored on 8 outputs. Used ESP 32 with MarcMerlins code and some help and advice from Yves Bazin
Spectacular! Looks incredible
@Jeroen_van_Dorsten great job !!!
Nice looking.
- what is the intended use/display location?
- you said you used my code, do you mean you used NeoMatrix to do the mapping and/or use Adafruit::GFX primitives underneath?
Your poor camera can’t handle it
@Marc_MERLIN The strips end up in a plastic transparant tube and will be placed in an entrance of a club.
the code i used https://github.com/marcmerlin/Table_Mark_Estes
Only adjusted the numbers of strips and length of the strip
@Chris_Parton thanks
@Yves_BAZIN thanks
@Kevin_White thanks
@Will_Tatam had to adjust resolution to directly post from my phone
@Jeroen_van_Dorsten you are welcome !!!
Can’t wait to see a video of full of animations.
If you want to use artnet to display stuff let me know.
@Jeroen_van_Dorsten interesting, I’m glad Table_Mark_Estes worked for you in a matrix that is so far from being square
@Yves_BAZIN thanks ! I sure will dol
First i have to install this all and make it work. Then i will test alot of stuff on it…cheers!!
@Jeroen_van_Dorsten thanks!
