I do not see anything wrong in that diagram. Can you unplug everything, and inspect the board to see if you can locate a particular place that has burnt ?
There´s some flux recidue on the back of the GLCD adapter, exp 1.
By reflecting and playing with light, i suspect there´s a small solder bridge on 2 pins on the back of the USB connector?
Of this i can´t be certain, but it looks strange.
I need to access a microscope to rule out the solderbridge, the guy who lends me the crimp pliers might own one.
And i´m returning them tomorrow morning, hopefully a close up inspection will be conclusive.
After close scrutinizing of components and solderings, no burnt components could be found.
The bridge between the USB pins was removed, also the flux residue.
In what steps would you recomend to start hooking the wires back together?
Is there any way to “Ask” the board if it feels alright? Some kind of diagnostics?
Hi!
I started to reassemble the printer yesterday.
I have jogged it in X Y Z + extruder from Pronterface and done the homing sequence for X and Y.
The steps/mm is configured and the speed in XY in incredible, 20000 mm/ min without loosing steps!
I have some mechanical issues in Z, but that´s not smoothies fault,
This was done without the GLCD. But it too, seems to be working fine. (Have not tested its full functionality yet)
Work will be resumed in the weekend.
It seems so far to have survived the smoke. Time will tell.
Perhaps the small short out generated little heat, boiling the flux and made smoke? This is my theory as of now.
//Henrik
