6-axis cnc motor?
I see in the docs that there is support for 6-axis with the CNC firmware. I currently have 5 motors connected (and working) to the existing normal connectors using external drivers. There isn’t a labeled connector for a 6th motor. Can I simply use some of the other pins, like P1.30, P1.31, and P1.23 and connect them to my external driver?
If it helps, I’m building a CNC with a material autoloader. I would like to have the standard XYZ motors, A will be a second Z head, and B & C will be used to feed the material and hold it in place.
Thanks!
Yes, you can use any pin to control any motor, you are completely free.
Cool project btw.
Thanks for the response. I got it working. I have a couple of other things to work on and when it’s done, I’ll post a video here.
