A AXIS? , how do you make the A axis DRO update, also is there one for the machine DRO? i can see the A in the first DRO, but its always 0, after a G0Ann/G1Ann
Which controller are you using? Tinyg or grbl?
tinyg
Thanks for providing that bit of info. I don’t have an answer for you but hopefully someone here is more knowledgeable with 4th axis.
Do you have the A axis configured in tinyg? ChiliPeppr only displays what the controller tells it, so if it isn’t changing that suggests the controller isn’t reporting a axis information.
well the motor is moving around on a G0Ann/G1Ann command so i’d say its setup.,the other axises do update on XYZ moves.
