A ChiliPeppr user named fl@c@ just sent me a picture of a TQFP32 board he made from ChiliPeppr’s Eagle BRD Import. He is getting better results than he ever got from the pcb2gcode plugin most of the world uses inside Eagle because ChiliPeppr lets you “deflate” your paths. He’s using a novel vinyl cutting technique with a diode laser to create his masks for etching. I can’t believe the picture he sent. Those are gorgeous results.
https://cdn.hackaday.io/images/67561428785200220.jpg
@jlauer that looks really good. Do you have any further detail on the actual process / equipment used for the vinyl mask technique?
@Chris_Fraser this looks like a winner method! We need to get some vinyl!
