A couple months ago I designed an overhaul for my cobblebot vanguard since the original design is awful. Ever since I’ve had layering problems that I’m convinced is horrible z wobble because the threaded scre nuts are on long bars, but may just be extrusion. Does anybody think it’s z wobble and if so how to fix it?
Do your have a belt installed? If yes, are you tensioning it?
What is that by the endstop? Looks like springs?
The x and y axis have belts that are pretty well tensioned, the x axis belt isn’t visible behind the v-slots
Do you have any springs or tensioners on the belts?
I have tensioner on both
Photo…
It’s it a spring?
What kind of couplers you are using between motors and lead screws? One problem could be your z-axis motor setup. Basically you are holding whole z-axis weight axially on the radial bearings of the stepper motors. And if you have a flexible coupler between motor and lead screw, you have added practically a spring there.
You could try to support the lead screw with an axial bearing from the bottom of it (radial bearing will also do well in this case).
Everything feels solid, it doesn’t seem like the coupling is causing it but it could be
Tension the belt without the spring
It’s the same issue I had on my CobbleFlop.
Remove the springs on the belt.
It causes your rippling…
Really? I’ll try that. You don’t think anything is wrong with the z axis?
Yes, springs in your belt flex. and cause ripples.
You need to ensure belts are tight (like plucking a guitar string)
Z axis should be ok.
I do however recommend you upgrade your setup, as per @Tinkering_On_Steroid
I would , but I wanted a Taz style geared Wade extruder so I had to make my own
Thanks for your help
