A couple of days ago, I mentioned here I was using cheap chinese TB6600 drivers from ebay.
At first, everything seemed to works just fine.
But lately I got the feeling these drivers were not delivering the power I expected.
My extruder still seemed a little underpowered.
So I decided to measure the current running through my steppers.
I had adjusted the dip-switches to limit the current to 2,5 A.
But the current never exceeded more than 1 A.
A quick search on the internet solved the problem. The driver chips are, due to a faulty design of the printboard, limited to 30% torque.
Only after connecting pin 24 with pin 3 of the stepper driver, the torque is at 100%. The difference in power is staggering.
There is no way I can stop my extruder by holding the big gear with my bare hands. Before this, I could easily make the extruder skip almost by looking at it
So, if any of you are considering these drivers, be sure to make this adjustment.
But I also have a question. My stepper motors are rated for 2,5A.
Is this total current (two coils) or current per coil?
My steppers get quite warm now.
