Achieve the smoothest finish on your ABS parts
http://www.thingiverse.com/thing:1940791
for very tiny parts and obviously for ABS only
ABS only for sure. The size of the smoothed part depends purely on the size of the vessel you are using. My current useful (cylinder) volume is 30cm x 15cm diameter.
I tried an aquarium but count’s get a motor working that is outside the flamable volume.
@Marcus_Wolschon maybe use a magnet or group of magnets to turn a wheel with metal on it. Like a science beaker.
How to keep a space between the glass and the part and how strong does a magnet need to be to hold 0.4-1.4Kg of material on a 400mm lever?
In my head in envisioning a stand inside the container that supports the rod. Pla might be a good option. As far as how strong of magnets I’m not sure someone with more knowledgeable than me may know… I’m a trial an error kinda guy.
@Jeremiah_Coley PLA dissolves destructively in Acetone/MEK. Wood may be an option.
