Alright here is a question, is there a way to make it stay on one location longer while firing? I have a design that requires pinholes, and I sketch them up, but it zips through them so fast only getting 1/2 penetration and that is with power set to 100%. I tried to run it a few times, and the holes were not 100% lined up, maybe .25 - .5mm off, but it shows when you look at it as they both only go half way through lol.
They are little circles. .10 circles actually.
Was a separate drawing, will try setting the feed to 1 and see what happens o_O
You can use “M3S100 G4 Py M5” to wait y seconds (or milliseconds) but it depends ou your controller if the laser can fire at this time.
It is acrylic and it’s not melting closed, can see it only gets half to 3/4 the way through
Will will try decimals in a minute. And @cprezzi I am using the C3D mini.
