Alright my 3d printing friends.
Alright my 3d printing friends. I have a problem I need u to help solve. I have a borosilicate glass bed 3.3mm thick and 700mm D diameter (actual print space little over 630mm diameter). I need to heat this puppy. I’m thinking of running 4 separate silicone heaters in parallel. Any ideas on how to wire this up? Or does anyone have a better a solution? Thanks!
thanks for the quick reply, @Ross_Bagley . i was thinking along similar lines. I cant remember, but i think i faintly recall now that @Thomas_Sanladerer running a printer with multiple zones in it or the like as well.
May i ask where you sourced the large borosilicate plate?
paid 91.57 , but bad customer service.(grouchy guy). place is called http://wwwcincinnatigasket.com
if i had to do it over again i’d probably go for 5-7mm thick
I’ve not had that much of a problem, but I’ll keep an eye out
Get yourself something like this. SSR is all you need other than this:
Agreed with @Mark_Rehorst and @Ross_Bagley . I would get a mic6 bed and put a piece of PEI on it with a silicone heater mat under it and use an SSR on mains power
Thanks for all the suggestions folks!!!
SSRs can have control voltages down to 3V. So you can even run one on a spare microcontroller pin if you wanted, saving the FET for something else.
@Griffin_Paquette PEI directly to aluminum plate? They have enough thermal expansion mismatch that I wouldn’t do that for larger than desktop bed sizes.
