Alsatian house frame in a Multi-Purpose box.
I left a sketch of historic structure of Alsatian house. I just rounded the angles to make it printable without support.
Print with any plastic. I did it in pla-wood.
Think about putting a retraction for quick moving, not like me. Otherwise you have small wires very long to remove.
All windows, doors, and beams do not need structures to print. And do not add, the spaces between the beams are complicated to clean
Printing time: between 2h and more if affinity
Size: 88mm * 82mm * 115mm
File creates solid, so no hole and no need to fix something. All angles are broken with a radius to avoid retouching.
Enjoy
