Amperage Rating for Nema 17 Stepper Motors
So, I bought four 2A/phase, 4.5Nm Nema 17 Steppers. Will a 2A/phase current draw be ok on the Smoothieboard 4x? What does “per phase” even mean? If I go down to say, 1.8amps in the software, will the torque provided be enough to power a bowden delta 3D printer?
Here are the stepper specs:
Manufacturer Part Number 17HS16-2004S1
Motor Type Bipolar Stepper
Step Angle 1.8°
Holding Torque 45Ncm(63.7oz.in)
Rated Current/phase 2A
Phase Resistance 1.1ohms
Recommended Voltage 12-24V
Inductance 2.6mH±20%(1KHz)
Physical Specification
Frame Size 42 x 42mm
Body Length 40mm
Shaft Diameter Φ5mm
Shaft Length 23mm
D-cut Length 21mm
Number of Leads 4
Lead Length 1000mm
Weight 310g
I’m currently planning on using a 12V, 400W power supply.
Thanks!
Hey.
2A per phase means 2A, pretty much.
Smoothie can handle up to 2A, but might require some heavy cooling at that value. I generally use 1.8A with 2A motors, and aim a fan at the board. You only loose a tiny bit of torque, it should be perfectly fine for an extruder.
Cheers.
Thanks Arthur! Really appreciate the response. I’ll try it at 1.8amps with some cooling and see if I’m getting enough torque.
Regards,
Leo
