Another low profile product from Molex.
Another low profile product from Molex. Less than 5mm height, rated for 9A per pin. Easy installation and removal. Not sure how it would hold up on something that’s moving, but that’s not quite what it is designed for.
http://www.molex.com/molex/products/family?key=litetrap&channel=products&chanName=family&pageTitle=Introduction&utm_source=ds&utm_medium=lit&utm_campaign=mpd&WT.mc_id=A02045&utm_campaign=ssl&utm_medium=gmap&utm_source=Eloqua&WT.mc_id=ssl
These would be great on a shield too, instead of the screw type connectors.
If you’re going for low profile, yes. They take more space lengthwise compared to a regular Euro block screw terminal: 11.80mm versus 7.29mm. Granted the Euro Block is a through hole piece, which I like because it’s less likely to rip off of the PCB if something were to yank on the cables.
Lite-Trap Drawing: http://www.molex.com/pdm_docs/sd/1041880110_sd.pdf
Euro Block Drawing: http://www.molex.com/pdm_docs/sd/393570002_sd.pdf
