Another newb question. If I've been modelling something in Wings3D (the excellent version from
Another newb question. If I’ve been modelling something in Wings3D (the excellent version from ggaliens) is it possible to map certain parts to the fill type needed? E.g. 100% fill where bolts are needed, 50% elsewhere? Either by mapping colour or some other attribute that Slic3r will understand? I’ve done some Google searches and I’m not finding what I’m after.
Slic3r supports modifier meshs - basically, you create a second, intersecting part and Slic3r will let you modify a bunch of slicing parameters for the area where the two parts intersect.
The short answer, not to my knowledge.
A possible work around, could be to design a small mesh support inside the area you want solid infill. Use the silc3r setting that dictates what happens to areas under a certain “x” mm^2. “Solid infill threshold area” I believe is what it’s called.
It’s not the greatest solution in the world but it will get you to a place close to where you want to be.
Hope this is somewhat helpful.
Thanks guys, I’ll give those ideas a try.
The second of the two options is probably the one I’ll run with as I don’t have to mess around with object positioning in Slic3r and all of the data is kept in the one STL file.
