@funinthefalls as one of us that spends a lot of time troubleshooting problems and documenting solutions in this community I find myself spending way to much time retracing problems and solutions. “Been there done that”… Deja vu all over again"…
I think we are getting to a point in this community that we have seen almost every kind of problem possible (or close to it) and have some pretty good solutions.
I also notice that the majority of the posts come in two major categories:
… Advice: getting advice
…Problem: looking for a solution to a problem.
We all know that searching the community is frustrating. Even to the point where many of us have collections that focus and collect on key subjects.
It dawned on me that part of our search problem may simply be that our “filter” categories may not be granular enough.
So I am wondering if changing/adding to the filter categories can help us better find existing advice and solutions.
Here is a set of categories that illustrate my thinking:
Advice: PWM & L CONTROL
Advice: LASER POWER SUPPLY
Advice: OPTICAL COMPONENTS
Advice: COOLANT
Advice: LASER TUBE
Advice: GANTRY
Advice: AIR ASSIST
Advice: AC POWER
Advice: LIFT/STAGE
Advice: CONFIGURATION
Advice: CONTROLLER
Advice: LASER FINDER DOT
Advice: ENDSTOPS/INTERLOCKS
Problem: PWM & L Control
Problem: LOW OPTICAL POWER
Problem: LASER POWER SUPPLY
Problem: OPTICAL ALIGNMENT
Problem: COOLANT
Problem: LASER TUBE
Problem: GANTRY MOVEMENT
Problem: IMAGE QUALITY
Problem: AIR ASSIST
Problem: AC POWER
Problem: LIFT OPERATION
Problem: ENDSTOPS/INTERLOCKS
I don’t know if there is a limit on categories or how to change them. I know it seems like a long list but I sense this level of granularity would improve our search filters and allow members to do some searching before posting. Often solving their own problems.
To use these categories one decides while posting if they are looking for advice or a fix and then choose the appropriate subcategory.
If we had to make the list shorter we could loose the ADVICE/PROBLEM and just keep the subsystem granularity. But I hope not :).
…BTW I have also been noodling how we can provide troubleshooting methods and reporting because I find myself repeating a troubleshooting, testing approach and asking for the results…
Examples are:
…Testing a LPS for proper operation
…Verifying the PWM control is working
With these filters we could post in each categories section a standard and proven way of how to identify, report, troubleshoot and test a problem in that category. This would dramatically reduce the amount of churn when trying to help someone with a problem.
What are your thoughts?
