@funinthefalls @Stephen_Sedgwick1 @Ariel_Yahni_UniKpty @Yuusuf_Sallahuddin_Y
Here is 1 of the 4 screw shaft assy. on my table. I got this as a replacement for a bent one.
So is basically a leads crew, 2 bearings, a teeth gear and some nuts?
Yes, the 4x lead screws are driven by a cog belt that wraps around the 4 cog pulleys (one on each corner) and driven by the stepper. The plate is captured between the nuts.
I’ve seen slightly different methods of holding the plate, using a 1 piece nut piece that attaches to the plate. Thanks for sharing Don.
