Any body here have experience with RDC6442G?
Any body here have experience with RDC6442G? I set the machine home position in the bottom left. Everything is works fine except the preview image on the RDCS6442G screen is mirrored. This happend when Y mirror is disable in vendor setting of RD Works.
If i enable Y mirror in vendor setting, the preview in RDC6442 screen is correct but the laser draw the object as mirror.
Any one know what is wrong?
Disable the mirror Y in the software, then press the Z/U button on the controller to enter the menu. There’s a screen origin setting on the controller itself that you need to change.
Hello ALISHA KANSHA I have updated my k40 with the controller rdc6442g but I have not been able to use it, for configuration reasons or at least I think you can publish your configuration I would really appreciate it thank you
Hola ALISHA KANSHA he actualizado mi k40 con la controladora rdc6442g pero aun no he podido utilizarla, por motivos de configuracion o al meno eso creo me puedes publicar tu configuracion te lo agradeceria de verdad gracias
@Manuel_Tejero what did you mean ypu have not been able to use it. What thing is not working? For me i just follow the user guide of rdc6442 for the setting and wiring.
@LightBurn_Software Anyway thanks for your help. Now everything is works perfectly
