Any chilipepper user here uses Shapeoko 3 with Grbl 1.1 with success?
I’ve updated to gbrl 1.1 its giving me huge jogging issues.
I am using the new workspace for the 1.1 on the website.
G20 and G21 don’t seem wanting to change half the time.
Jogging issue: Sending a command to the machine telling to move x distance will result in smaller movement than anticipated.
Anyone know if this is a known problem or it’s just a isolated incident.
Thanks
There is a known issue in some edge case scenarios with the jpadie workspace and grbl 1.1. In particular with mm/inches when a g code file is not loaded.
I had pushed a roll back that should exhibit the same behaviour as in the grbl workspace but I’ve noticed that the axis widget seems not to behave in quite the same way.
You will not get any issues if your gcode is in mm and if grbl 1.1 is set to report in mm. So if you are seeing issues let us know with JavaScript logs, spjs logs and a screen capture please.
