Any idea what could cause this on the few first layer on a delta using smoothieboard?
I’ve seen similar artifacts that turned out to be due to frame flexing or axis tilting at the extreme of Z motion, but only on Cartesian bots. The same might be possible on a delta, but unless your linear guides are bent, it’s hard to imagine how. An invalid belt path might do it, but a Bowden tube that is too short is probably a more likely cause.
Oh, I just replaced the extruder (for a bondtech, along with the upgrade to smoothieboard)… must be that! I’ll change the tube for a longer one.
Thanks for the idea!
Bonjour
Désolé en Français voir le réglage du courant des drivers moteurs mettre à la valeur préconisée par le fabricant diminuer l’accélération bon courage
@Whosa_whatsis Wasn’t that
@Patrick_Darrieulat Je vais essayer, j’ai remarquer que j’ai seulement ce problème avec les cercles… un cube par exemple sera très droit.
Le courant des stepper est peut-être trop haut et le moteur chauffe (je sais qu’il n’est pas trop bas, il ne skip pas de steps).
L’accélération, je vais lire la dessus!
Just an update, seems that one of my pulley was a bit loosen, causing slip only from one side. I fonds that trying to move the belt while the motor were holding.
Thanks for suggestions, I’ve tuned some settings hehe
