Any ideas why my viki2 button might be flashing like that? I’m running smoothie on an Azteeg X5 GT
It’s just having itself a little lightswitch rave is all.
I mean all for parties but at work, we hold ourselves to more “mature” standards.
Check if the pin number for the color change is not used elsewhere.
Or, maybe, activating the heater is causing voltage drop .
I’m using a solid state relay to control the heater so it cant be that. I’m also running dual extrusion. What I think is happening is its trying to show blue for the extruder that isn’t being used and red for the extruder that is being used and its just switching back and forth between the two.
So try to heat each hot end one by one without running a part and then both together.
